Saving complex numbers?
Hello all,
I need to save a calibration file...simple enough, but my calibration file is an array of complex numbers. I tried to find the proper precession (ie. %.3f) but I couldn't locate the precession extension for complex numbers. When I try to save the array I loose all of my complex numbers...so how do you save an array with complex numbers?
Thanx
Azazel
Azazel
Pentium 4, 3.6GHz, 2 GB Ram, Labview 8.5, Windows XP, PXI-5122, PCI-6259, PCI-6115
(3,652 Views)
I think you have to separate out the real and imaginary and save a 2 column array.
Randall Pursley
(3,640 Views)
You can try the attached VI which is a modified version of Write to Spreadsheet File function so that you can now write complex numbers to a spreadsheet or text file.
Ankita
(3,618 Views)
how about using the XML functions? With this I found it very easy to save and recover any data I want... (look under advanced/data manipulation/xml)
Carsten
(3,605 Views)
Thanks all for the help, I went with the 2 column spreadsheet approach.
Azazel
Azazel
(3,597 Views)
