Save multiSlide values?
I'm working with MGI save settings "sample attached below" the problem is that i have simple multi slide "slide control" but i can't restore the two slides value, only one slide is restored!
when i browse the saved config file i fond that the two slides saved under the same name, how can i save that slides values under different names so i can restore them?
attached snippet explain the problem
(4,211 Views)
can you down convert to 2015 and share ?
(4,169 Views)
can't attach zip or vi " i got big red error about extention!"
but here is the sample i'm using , just add slide with 2 or more slides in and see
forums.ni.com/ni/attachments/ni/170/945531/1/MGI_save_and_restore_example.vi
thank you
(4,162 Views)
any help for my problem yet?
(4,133 Views)
You are having problems with a function you installed from the LabVIEW Tools Network that originally came from MooreGoodIdeas (MGI).  I recommend you go to their home page (easily searched) and see what they advise.
(4,128 Views)
