Save image as it show on display without changing the scale
I do not think there is something to do with the dispose function. I removed it from the program, and it still does not solve the problem. Probably dkfire is right, the Get image method does not work for IMAQ images. Thanks for your kind suggestions though.
Message 11 of 33
(1,626 Views)
It's not that nothing is saved. The image data from the display is saved, but just the brightness is auto-scaled, so it too dim to see any features in image. so what I need is to save the image with a fix colorscale or as it is shown on display. Cheers!
Message 12 of 33
(1,625 Views)
Something seems wrong with the method you were trying to use.
Try...
Right-click the image indicator and select "Create reference"
Right-click the reference node and choose "Create >>> Method for Imaq.... >>> Get Image.
Then using the error wires use the Get Image method you created to get the image AFTER it is acquired and BEFORE the image is disposed.
Ben
Message 13 of 33
(1,620 Views)
Thanks! but as you can see, there is no method available for IMAQImage class.Picture4.png
Message 14 of 33
(1,617 Views)
Have you tried a control reference, like I suggested?
I don't know IMAQ, so I can't help you there, but my first suggestion works for everything else.
You can even get an image for a BOOLEAN control.
Steve Bird
Culverson Software - Elegant software that is a pleasure to use.
Culverson.com
LinkedIn
Blog for (mostly LabVIEW) programmers: Tips And Tricks
Message 15 of 33
(1,616 Views)
Is there a reason that you won't wire it up the way my diagram showed?
Steve Bird
Culverson.com
LinkedIn
Message 16 of 33
(1,612 Views)
Certainly no! Here is a saved image using your method, it kind works, but the frame of the display is also included in the image, which is not good from my prospective. I need to process the image later in Matlab.test3.png
Message 17 of 33
(1,609 Views)
OK, then use IMAGE SUBSET to specify a rectangle that is the area you want.
Steve Bird
Culverson.com
LinkedIn
Message 18 of 33
(1,607 Views)
Look at what I wrote again.
Create the reference for the indicator NOT the Imaq wire.
Ben
Message 19 of 33
(1,604 Views)
Thanks! but if create a reference for the indicator, the frame of the indicator will also be included in the image, see below.test3.png
Message 20 of 33
(1,600 Views)
