Save for previous version from 2015 caused problems
Hello all,
I did a CLD practice run using the Sprinkler System example. I built it in LabVIEW 2015, and then saved it for previous version to LabVIEW 2014 before posting in the Certification forum for comments. When it was opened by another member using 2014, the Read Delimited Spreadsheet.vi was not found. I can't duplicate the error because I don't have an install of 2014. The original thread is HERE. I have attached both my original 2015 project and the 2014 "Saved for Previous" version. Also attached is a screen shot from the attempt to open the 2014 version. Could this be an issue with the backsave?
Thanks to all.
Dan
(3,130 Views)
Accepted by topic author DanRen_IQA
The Read From Spreadsheet File was deprecated and replaced with Read Delimited Spreadsheet.  This is actually expected to break.
(3,122 Views)
