Save data
Hi, i have a problem with visa address, every time before running my application, i need to select the GPIB address to access the resoure, so how can i save this information as default?
thanks
(2,732 Views)
nkf,
If you right click on the control a pop up menu will appear. Look for "Data Operations" menu and then select "Make Current Value Default". That should do the trick.
Cheers,
--Russ
(2,727 Views)
Or make this address a 'constant' on your block diagram instead of a control on your front panel
(2,715 Views)
