Save data
@alhabeeb wrote:
Then how to wire it to the Write to Text?
No, you still need to add the relevant row and column delimiters. Just use an array and turn it into a delimited string, same as with the DBL data.
sketch:
Why have all these string diagram constant if you could use an array diagram constant.
Message 21 of 47
(1,910 Views)
Thanks a lot.
Is it possible to save in excel file?
Message 22 of 47
(1,893 Views)
Hi alhabeeb,
Currently you create CSV files, which are considered as "excel files"!
Message 23 of 47
(1,888 Views)
OK thanks.
If I want to add time to my data, I need just to wire it like this?
Message 24 of 47
(1,882 Views)
what does the file look like ? Did it work ?
Message 25 of 47
(1,872 Views)
Hi alhabeeb,
With hidden wires under case structures???
You can wire it like that - when the output of HighResTime is useful for you…
(Otherwise you need to calculate a more suitable time value.)
Message 26 of 47
(1,873 Views)
another 2 cents. you can include this part of the code inside the Case , so it only executes when is time to save data.
Message 27 of 47
(1,869 Views)
@alhabeeb wrote:
OK thanks.
No. You should branch from the same wire as going to the "elapsed time" indicator. The output of the high resolution timer is not useful.
Assuming you want elapsed time. If you want absolute date and time, different code is needed.
Message 28 of 47
(1,861 Views)
I'm thinking to create an increment by 1 then multiply by the elapsed time. So each true case the counter increased by 1. For example the elapsed time is 5 (s). First ture case the total time is 1*5, the second true case 2*5, the third true case 3*5,... so on. I did it as shown in the pic. but I had an error.
Message 29 of 47
(1,846 Views)
It is OK now. First time 0 (s) , counter*second elapsed time. If there is any suggestion please let me know.
Message 30 of 47
(1,843 Views)
