Save custom scale while associated task is running
I would like to know if it's possible to change the value of a custom scale while a task (using this scale) is running ?
If yes, when will the new coefficients be applied ?
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(2,324 Views)
On the deivices I used, you have to stop the task and restart it to apply a different custom scale.
Consider doing scalling "on the fly" with formula nodes, Polynomial Interpolation, lookup tables, or whatever works for your scale. This way, changing on the fly is easy.
Richard
(2,309 Views)
That's what I was afraid of.
The idea was to keep all the settings relative to the hardware in a nce file... even the scales !
So i guess I'll have to add scales info in my app configuration file.
Thanks !
(2,305 Views)
