Save columns/rows into file with headers
Jamiva's image is a VI Snippet - if you have a version of LabVIEW newer that the listed version (2016 in this case) you can drag and drop the image onto a block diagram and it will create the code.
Don't copy and paste though - then you just get an image 😞
GCentral
Message 11 of 14
(1,402 Views)
I only have 2013 available at the moment so I can't use the drag and drop functionality with that image
Message 12 of 14
(1,397 Views)
GCentral
Message 13 of 14
(1,384 Views)
Thank you! I didn't realise at first you have to save the image locally, then drag and drop.
Unfortunately, as I expected, this code does not do what I want. It appends row-by-row not column-by-column. I appreciate the help from everyone but I can't see any way to further optimize my code.
Message 14 of 14
(1,363 Views)
