03-17-2021 04:11 AM
I have come accross this issue several time, and I havent find a suitable solution yet. I am builing applications which can be used with different systems, so I have a configuration file which can be saved and loaded to save the user from changing all parameters everytime they re-open the main VI. These informations are for example: folder for saving data, acquisition rate, name of the variables to acquire.
The thing I cannot figure out is how to include in this the line properties which can be chosen by the user. For example, user1 usually acquires and plot a hot and a cold temperature, so he chose a red and a blue line. User2 usually acquires a speed, and three pressure, so he would prefer to have the speed in white dashed line and the tree pressure in plain red, green, blue lines.... These are exemple but in my application there are many many variables and it is important to have a convenient color scheme, but very tedious to change it all every time you open the application.
Any way to do this? My current solution is to generate one application per user with the right default plot properties, but I dont like it so much...
Thanks!
03-17-2021 04:34 AM - edited 03-17-2021 04:36 AM
Hi Marine,
Most plot properties are just numbers (line thickness, line color, point type, point color, …), so you can save them to a configuration file like any other numeric value!
Read the properties and save them to you rconfig files. Upon executable start (or on user request) read the config file and set the properties.
I do this in several executables too, so users can adjust their favorite color scheme for graphs…
