Save With Options
In LabVIEW 7.1, ther was an option in the File drop down menu called Save with Options.  It gave me the option to save all VIs in one .llb.  I do not see this in ver 8.2.  It made portability much easier.  Is there another way to do this in 8.2?
Thank you in advance for your help.
Ron Deavers, CLD
(3,740 Views)
Yes 8.2 retains that feature Smiley Wink except it asked for more options when the "save as" is selected.
(3,729 Views)
You have several options:
(1) "Save as..." allows you to create a new llb and save the current VI in it.
(2) If you want to save the entire hierarchy, you need to make a project and create a "source distribution". (Look under "packaging options...custom").
(3) You can use the llb manager ("tools...LLB manager"). Here you can e.g. convert a folder containing VIs to an llb or vice versa.
(3,726 Views)
