Save Graph to File
Hi guys ,
    I am developing an application where i get an output graph for running a test over a period of 4 hours. I need to save the graph in a file. I tried to work with excel and word report generation Vis but cannot get the result. Any idea how to save the graph as image in a file ?
Bhushan
For Latest TECH News check out my blog at http://directfromdigg.blogspot.com
(3,604 Views)
I do not have the word/excel report vi. But I do know that in the regular report vi's that there is a vi to take the front panel control and append it to a report. all this vi really does is make a jpg image of the control. you could try this.
Joe.
"NOTHING IS EVER EASY"
(3,597 Views)
I have attached a VI to export the graph to a jpg file.  Instructions inside.
Paul
(3,589 Views)
Are you trying to save the data from the graph to a file or just place an image in a report?  If you are saving the data only you just need to format the data and save it to file usually a tab deliminated format is good since it is easily exchanged with other programs (use a binary format if the data set is vary large).  If you just want to obtain an image of the graph indicator use the  invoke method >> getImage which lets you get a image of the object that you can save as a image file or include it in a report.
Paul
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(3,586 Views)
Thanks a lot all of you guys. My application is working as i wanted.
I appreciate your help.
(3,564 Views)
