DSA excitation control.vi with labVIEW 7.1
Hello to all people, I need to adquire an acceleration signal by using traditional DAQ  but my "DSA excitation control.vi" don´t work in labVIEW 7.1. Is it possible to do that? or I must use the DAQmx. I suppose that i could use any of both drivers. Thanks.
See U.
Jorge.
(2,477 Views)
Hello Jorge,
Could you post what hardware you are using?  The answer to that question is very dependent on how to attack the problem.  Also, I have Traditional (Legacy) NI-DAQ and NI-DAQmx support for LabVIEW 7.1 on my system and don't have a "DSA excitation control.vi".  Is this a custom VI that you wrote?  If so, what sub-VIs are causing the problem?
-Alan A.
(2,466 Views)
