Sampled data representation
Colleagues NI forum would like to have help to develop a VI to display the sampled data saved on my computer in .xlsx format or txt, and play these data in a VI with the same sequence , obeying the order and rate at which were sampled . Thank help everyone.
(3,172 Views)
http://zone.ni.com/reference/en-XX/help/371361J-01/glang/read_from_spreadsheet_file/
Then loop at your sample rate writing to a chart with each iteration. If the sample rate is too fast, then write chunks of data at an appropriate rate to match the sample rate.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(3,141 Views)
