Sample Clock
I am using Labview 8 on Windows XP along with a PXI 6602 and SCB 68.
I am using incremental encoders for my project.
I just want to verify that when the programs asks for sample clock I should choose the 80MHz timebase
Any information is greatly appreciated.
Thank you,
SparkEE
(4,085 Views)
In LabVIEW, you can navigate to "Help >> Find Examples".   In the resulting window, click the search tab.  Search for "encoder" and there should be three examples that show up which start with "Counter - Read Encoder".  These examples will show how to set everything up and should get you up and running.
(4,032 Views)
The examples will show good procedures for making this measurement, the question of correct time base is a little more complex.
The issue is that your counters aren't infinitely long. So the right time base is a trade off between resolution and how long a period you are wanting to measure. You want it fast enough to give the resolution you desire, but not so fast that it overflows the counter.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(4,008 Views)
