Sample Clock and Digital Waveform (1Channel NSamples)
I need to sampling digital input using NI USB-6001 device. I have never do sample digital inputs before, but did it many times for analog inputs, so I just copy sampling part from another project with analog inputs and make some adjustments, see screenshot below. Now I have a problem with Sample Clock, it gives me error -200077. Bypassing Sample Clock is working, but it is not what I need, I need to specify rate. Where is my mistake and how to do it properly?
(2,859 Views)
Accepted by topic author SergeS
The problem is that your device simply does not support the use of a sample clock for Digital tasks.  That's the meaning of the help text stating that only "On Demand" sampling is valid.  This is sometimes called "software-timed" acquisition. Your application software queries for a sample when it chooses to, and one is delivered on-demand at that moment.  But the device can't free run in the background with a sample clock and buffer.
-Kevin P
(2,813 Views)
Ok, thank you. Have done it by reading digital input in the loop. I do not need precise timing so it is ok for me.
(2,775 Views)
