SUM in array
Hello Everyone, i'm making sub vi , to find the area of a signalafter cutting the thresholdafter cutting the thresholdbefore cutting the thresholdbefore cutting the threshold
Message 1 of 11
(4,730 Views)
Do you want to exclude the signal that is inside the threshold, i.e. set these values to zero?
Should the negative values have a negative or positive area?
Do you want a separate output for the negative and positive parts or combine it all?
We recently solved a very similar problem. Try to find it. No matter the requirements, the solution will be trivially simple.
Message 2 of 11
(4,717 Views)
hello everyone, I'm making a sub vi, to find the area of a signal, this program is my project to implement wheelchair movement using open bci from human brain signals. so in this program I want to cut the signal using a threshold, then I will add up the obtained signal later, from the signal that does not pass the threshold it will be worth 0, the value of 0 is also a separator to be able to increase the value of the signal that passes the threshold.
Now I'm having trouble summing up the signals. so can someone help me?
Now I'm having trouble summing up the signals.before cutting the thresholdbefore cutting the thresholdafter cutting the thresholdafter cutting the thresholdthe data i want to achievethe data i want to achieve
Message 3 of 11
(4,715 Views)
(Sorry, I don't have LabVIEW 2021 on my current computer. consider "save for previous" before attaching.)
See if this discussion can give you some ideas. Problem seems almost identical, except that you seem to subtract the threshold values from each side, making the absolute peaks smaller accordingly.
Message 4 of 11
(4,688 Views)
oh sorry, This is for the 2018 version of Labview
Message 5 of 11
(4,636 Views)
This is basically the exact same code that was posted in this thread . Where did you get it from? (And why do your controls not have typical default data for testing?)
Did you even try my solution??? It should work with no to minimal change.
Message 6 of 11
(4,624 Views)
From your image, it seems you want B rather than A. Is this correct?
Message 7 of 11
(4,619 Views)
yeah that's right
Message 8 of 11
(4,592 Views)
So use my code and subtract the threshold from each sided data before summing. Should be trivial to do. Have you tried?
Message 9 of 11
(4,566 Views)
Did you figure it out?
Message 10 of 11
(4,491 Views)
