SSI (Serial Synchronous Interface) displacement sensor.
Thanks advanced for your reply.
How can I measure the signal from SSI (Serial Synchronous Interface) displacement sensor (MTS) with NI CompacDAQ or other products? Which module should I use? How to interprete the signal with Labview8.2?
jason
(6,054 Views)
Hi Jason,
There is another discussion form that has worked on this same issue. Please look here for further information. If you have any further questions please let us know.
Regards
Krista S.
Applications Engineering
(6,034 Views)
Thank you very much.
Can I apply the SPI card to measure SSI signal? I think they are different.
(6,014 Views)
Hey Jason,
Regarding the terminoligy, I think they're the same. Just check out this external forum where people discuss the differences. Also, there is a Connexions Article, that mentions one describing the other, so I think it can also be seen as a subset.
Nick D.
(5,986 Views)
