SRS example & error -200265
I'm trying to deploy an example code of SRS, from sound and Vibration toolkit.
Configuration done with cRIO-9045 and NI9232 card with PCB's 352A91 accelerometer.
After run, VI returns error -200265.
How to correct trigger signal?
(1,701 Views)
Error -200265 occurred at an unidentified location
Possible reason(s):
An attempt has been made to use an invalid analog trigger source.
Ensure that the trigger source you specify matches the name of the virtual channel in the task or matches the name of a non-scannable terminal that the device can use as an analog trigger source.
This is a DAQmx error. Without your code, the best we can recommend is that you follow those (above) directions to make sure that your code specifies a valid trigger source.
Doug
Enthusiast for LabVIEW, DAQmx, and Sound and Vibration
(1,652 Views)
