SCPI communication error
The instrument reports [No errors in queue].  USB SCPI is ON.  I don't know where to change the Windows USB power shut down - and I do not have Admin priv.  But it always hangs up on the VISA read immediately following the VISA write of command "SYST:ERROR?".  The error is occurring in "Error Query.vi" which is a sub-VI of Reset.vi.  As mentioned, this is in the Agilent 3446X driver example downloaded from NI.
Message 11 of 16
(3,052 Views)
Accepted by topic author Jim_Marihew
This sounds familiar:  Solved: Keysight 34461A initialize.vi not working - NI Community
I believe the main issue is Keysight's USB drivers.  I have seen strange issues with my 34461A when using USB as well.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 12 of 16
(3,031 Views)
Thank you NIquist!  I switched to ethernet and all is well 👍
Message 13 of 16
(2,982 Views)
Just another reason I avoid USB as much as possible.  Ethernet is my bus of choice for communicating with instruments.
Message 14 of 16
(2,972 Views)
Agreed.  It's a shame since it's so convenient, but I won't trust USB for mission-critical test systems.
EDIT:  Now that I think about it though, I do use a few of those NI USB-GPIB-HS+ adapters that are technically USB at their core and they seem pretty reliable.  Maybe that's why they have become crazy expensive???
I think the main issue might be the USB to Serial drivers hidden inside many instruments.  Even the good FTDI drivers can be flaky if not implemented correctly.
Message 15 of 16
(2,959 Views)
Yeah, I was taking the easy route because I am just taking some baseline measurements at my desk.
Message 16 of 16
(2,950 Views)
