SCC with multiple versions of LV
We are currently running software on version 4.1 through 6.1, and are slowly upgrading to 6.1. We are also looking to start using the SCC that comes with LabVIEW and are wondering if having multiple versions is going to cause us problems. If anyone has done this in the past, I would greatly appretiate a response.
Eugene
(2,835 Views)
Hi Eugene,
Keeping the versions straight with multiple devlopers that have different drive and file spec and ONLY USING ONE VERSION of LV can be complicated.
Do you really have people using LV 4.1 working on the same apps as the people with LV 6.1? How?
Ben
(2,835 Views)
I definitely have to agree with Ben. You don't want to be mixing many versions of LabVIEW VIs in Source Code Control. In general, it is definitely best for everyone to be developing in the same version of LabVIEW for any given project.
Matt
(2,835 Views)
You can set up a SCC master directory for each version of LabVIEW.
However, I highly recommend that each team work within the same
version of LabVIEW.
(2,835 Views)
