SCC checkin Error
Hi
I've indicated an error during check-in of files from the "user.lib" and
"instr.lib" directory.
The "SCC File Wizard" displays all files, that are not in the SCC project
and the listbox shows all dependend files. But the path-names of the files
are shorten by the placeholder "" respectively "". Both
placeholder will not be resolved during the check-in process. The procedure
failed, because the path-names are not correct.
What's wrong?
Mareike
(2,661 Views)
I had similar issues with SCC. My suggestion would be to specify a local working directory for SCC that is not under the main LabVIEW directory. So what to do if you want your VI's under the user.lib or instr.lib sub directories? My suggestion would be to make a utility VI that would copy your VI from the local working SCC directory to one of these sub directories.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,661 Views)
