SCC again (Instr.lib / User.lib)
I want to control my instr.lib and user.lib directory with SCC.
Should I create a top-level VI for each directory?
Should I create a "Top-" project-group including both directories to realize
cross-references?
How do I install additionally hardware-driver with a complex
directory-structure?
I'm still looking for a extensive "How to"-document for SCC (the document
http://digital.ni.com/manuals.nsf/webAdvsearch/57CC60D27B73A6FB8625665E00635
940?OpenDocument
is not deep enough!)
Mareike
(2,665 Views)
My suggestion would be to specify a local working directory for SCC that is not under the main LabVIEW directory. So what to do if you want your VI's under the user.lib or instr.lib sub directories? My suggestion would be to make a utility VI that would copy your VI's from the local working SCC directory to one of these sub directories.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,665 Views)
