取消
显示结果
搜索替代
您的意思是:
Running "LabVIEW 2010".exe as windows service
已解决!
转到解答
Hi all
years ago I wrote an application with LabVIEW 7.1 and turned it into an Windows NT Service according to this NI-tutorial.
Now I have a similar use case and I wanted to do the same thing with an application built in LabVIEW 2010.
Somehow it doesn't work and I've always get the error 62.
I've built a simple demo app once with LV7.1 and once with LV2010.
I was able to use the service when built with LV7.1 but not the LV2010 version (on the client side I've always used LV2010). So there is no problem with connecting to the server or using the port.
I'd rather not rebuilt the app with LV7.1 because it's not really small. I would only consider this if there is no workaround to this problem.
Anybody any ideas??
I really appreciate anybody's help
Cheers,
Christian
0 项奖励
1 条消息(共 11 条)
6,552 次查看
MS has changed the method for creating services.  I haven't created a new service in Windows 7 but I believe it uses an app called sc.exe.  Searching MSDN for the Windows 7 SDK and sc.exe should point you in the right direction.
0 项奖励
2 条消息(共 11 条)
6,543 次查看
Hi John
thanks for your reply.
Although the service should run on a Windows Server 2003 I will give it a try...
I'll report my results later
in the meantime,
have a nice day...
0 项奖励
3 条消息(共 11 条)
6,517 次查看
解答
接受人 oenk
Just as information for the one running into the same problems:
sc.exe did the trick BUT not as described in this Tutorial. You need to create a wrapper service like described on this Homepage. Services created with sc.exe need a BeginService() and an EndService() method otherwise it won't let you install it.
This picture shows you how I did it. The CIN loads AnyService.dll which itself loads server.dll.
Kudos to Kuan Chen
Cheers,
\c
0 项奖励
4 条消息(共 11 条)
6,486 次查看
The picture is too small... Cant read any of it.
0 项奖励
5 条消息(共 11 条)
6,471 次查看
Hi WayneS1324,
it should be better if you save it to your harddrive and load it from there. For me it was good enough.
Mike
6 条消息(共 11 条)
6,468 次查看
Addendum:
as marked in the solution it won't work right away.
The service.exe's ini-file won't work like described in the Tutorial "Creating a Windows NT Service Using LabVIEW".
After some time with trial-and-error, some tears, a lot of new grey hair and several cups of coffee I found the solution.
If you add the following shown property node entries to your service.vi you're good to go...
I don't know since when it was changed but it worked with LV2010 SP1...
Cheers,
\c
0 项奖励
7 条消息(共 11 条)
6,442 次查看
this information is really interestive but the Kuanchen website is no more active ....
anyone can help me ?
0 项奖励
8 条消息(共 11 条)
5,364 次查看
When I've wanted to run LabVIEW as a windows service I've used a third party command-line utility like SrvStart or SrvAny. Works great for me!
(blog)
0 项奖励
9 条消息(共 11 条)
5,320 次查看
I've never used this technique, but according to ShaunR on LAVA, you can use the Windows Task Scheduler to have programs get ran on starup, before login.  This is not making a service, but is is running a program before logging in, which is generally what people want when they make a service.
https://lavag.org/topic/17019-run-the-labview-program-windows-background/#entry104561
0 项奖励
10 条消息(共 11 条)
5,311 次查看
