Running multiple commands from labview in comandline
i want to run a programm on labview, that communicates with the comandline. First of all it should open Powershell which is possible by using a System Exec vi and the cmd /c command.
After that i want to run another command in the same comandline which is connected to the powershell. How do i combine these two commands?
Another solution would be connecting to the powershell directly instead of opening the comandline at all, so i can input the command directly to the powershell.
A third solution would be, to combine those two commands (hoping into the powershell and coding without pressing enter).
I do not know how to implement this in labview.
(2,908 Views)
There's this : Execute Multiple Commands With One System Exec Call in LabVIEW - NI
But you might need to use a pipe. That's where it get's complicated...
How about using .NET:
System.Management.Automation.PowerShell.Create();
That usually complicates things...
(2,894 Views)
Hi ranzinger,
the 4th option would be to create a batch file (with all needed commands) and just execute that…
(2,881 Views)
Thanks for the answer, what do you mean with using the.Net function?
(2,879 Views)
Or in LabVIEW:
(2,861 Views)
