Running data continuously in a database
That's just wrong as I guessed. You need to understand basic dataflow. Take some of free tutorials and then modify your program per either of my previous suggestions. As it is, you are passing a single value of each to the database loop and just writing the same over and over again.
Message 11 of 20
(2,225 Views)
Hello thanks for your comment and i will do as you suggested, also the data will be about the same for each as it is being sampled as in the picture i have attached. I expect the numbers to look like that in the database.
Message 12 of 20
(2,212 Views)
And you did not create a snippet as I asked. When you are done with the tutorials, read the help and try again.
Message 13 of 20
(2,210 Views)
Yes thanks and as my friend mentioned above the values will be the same and should look like this. I will watch the videos
Message 14 of 20
(2,198 Views)
_About_ the same isn't the same as _Repeated_. From the picture you'll send the last read value to be written several times in the database, that's probably not what you planned. Dataflow. 😉
SQL Express is a good suggestion mentioned earlier, the small differences between Access and MS SQL syntax wont bite you that way.
I assume you want DB Insert, not Update, you dont want to overwrite old values, do you? If you only want the last run in the table you can do a Delete * from [table] before inserting.
As suggested, make a small test vi which only writes some constants to the database to make sure that part is working first.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 15 of 20
(2,144 Views)
hey dennis thanks for your help i was able to successfully get the data to mysql database, you can see how i set up my code using code snippet as you asked. I also had one more question how would i send values back to my microcontroller to display on the lcd of my microcontroller, is there some special visa i need to use or what, as you see i want to send the frequncy and rms voltage back to the lcd on my micro.
Message 16 of 20
(2,086 Views)
That is entirely up to the code on the micro. There is no such thing as a special VISA. You would use a VISA Write and send a string that has the format that the micro expects.
Message 17 of 20
(2,074 Views)
yes i get that but to send the frequency, voltage and so on, i know i would need to convert to string but to send each to display on lcd would i use a cluster again or how would i tie each to the visa write. and the visa write would be located outside consumer look correct???
Message 18 of 20
(2,067 Views)
thanks for asking my comment steven lol
Message 19 of 20
(2,064 Views)
anyways dennis
i get it up to the micro code and i know i would need to convert to string but how would i send the data to the visa write, so the micro can display freq. and voltage. like how would i wire the two differnt reading for the lcd to the visa write. and would visa write be outside consumer loop.
Message 20 of 20
(2,051 Views)
