Running an external code for fpga target
     I want to run a dll file from a c++ code within the fpga target of a single board rio, but when i press the run button of the fpga vi (the vi which contains the call library function node) 5 target specific errors and warnings are displayed. The first error is Call Library Function Node 'Solar Position Algorithm.dll:spa_calculate': Node not supported in current target
Please I want a solution for this error
thanks
(2,925 Views)
FPGAs don't run dlls.
(2,918 Views)
You cannot compile a dll into an fpga. Solution: write the algorithm in native labview fpga code, write it in vhdl anf use a clip node, or pass the data to windows and run the dll there.
(2,916 Views)
  thank you for your reply
(2,899 Views)
