Running a Command in CMD vs LabVIEW System exec
I usually use something like
cmd /s /c "ticcmd --home fwd"
if my command that I would type into cmd is
ticcmd --home fwd
If you have quotes, the /s handles that too (so you could do)
cmd /s /c "mycommand_that_accepts_paths "C:\Program Files\Some Junk With Spaces\a.txt" "C:\Source\Other space filled path.txt""
noting the nested quotation marks...
As aputman said, this should all go in the command line input - not the standard input input.
GCentral
Message 11 of 12
(1,100 Views)
Hi JScherer,
In your  command structure "ticcmd --home fwd" ,"ticcmcd" is the actual command and '--home fwd' are the arguments.
Hence while executing this command ,you need to pass the absolute path of 'ticcmd.exe' (unless added to PATH variable) along with 'cmd /c' to the 'command line' terminal and then pass the arguments "--home fwd" to 'Standard Input'  terminal of the 'System Exec.vi' function.
If this way doesn't work, then try creating a batch file including that command and try to run using 'System Exec.vi' by passing the batch file to the 'command line' terminal.
Srikrishna
Message 12 of 12
(1,098 Views)
