Running a Command in CMD vs LabVIEW System exec
I'm trying to build an API for the Pololu Tic T500 ( https://www.pololu.com/docs/0J71 ) Stepper motor controller and am having an issue getting the system to respond to LabVIEW controls even though it does work on controls issued through the command prompt.
For Example: if I
  1. Open command prompt ( windows, type "cmd," hit "enter")
  2. Type "ticcmd --home fwd"
  3. Hit "enter"
The system homes to the forward position.
However, when I try to do the same in LabVIEW I get:
but without the motor moving.
What is the difference between the two methods, and how do I get the LabVIEW to execute the same as manually entering the value in the command prompt?
Message 1 of 12
(6,565 Views)
You need quotation marks around the ticcmd argument.  Make your string ticcmd "--home fwd".
Message 2 of 12
(6,543 Views)
Tried this, but no luck:
Message 3 of 12
(6,512 Views)
Use cmd /c.
aputman
Message 4 of 12
(6,497 Views)
This might help
=== Engineer Ambiguously ===
Message 5 of 12
(6,491 Views)
I tried this
No dice, I also don't get an output with cmd/c
Message 6 of 12
(6,488 Views)
One thing I just noticed is that when I go to Start -> cmd -> Command Prompt I get a window that says "Command Prompt." When I open one with LabVIEW, it looks like I get C:\windows\system32\cmd.exe
See below:
Message 7 of 12
(6,485 Views)
Check the 'standard error' output
Message 8 of 12
(6,474 Views)
What output do you expect from this command?
Try putting the whole command in the command line string (with and without quotes as Bob mentioned).
cmd /c ticcmd --home fwd
aputman
Message 9 of 12
(6,469 Views)
Try without the EOL constant. I wouldn’t have thought it was necessary.
Also, from a quick google it looks like ticcmd adds itself to the system path variable. Try using the path the the ticcmd.exe file rather than just ticcmd. I have never tried relying on system path variables with system exec...not 100% it will work.
Message 10 of 12
(6,459 Views)
