Running System Exec as Admin
I am trying to run system exec as admin using a batch file but always get an error saying the command isn't right.
Message 1 of 10
(5,983 Views)
What does "/r" mean?  I don't see that in the list of options when I run "cmd /?" from the command prompt.
Message 2 of 10
(5,964 Views)
Message 3 of 10
(5,947 Views)
It looks like you don't have a space between cmd and /r. You also need to create a shortcut to the command prompt that requires admin rights. See also https://forums.ni.com/t5/LabVIEW/Run-command-prompt-as-administrator-using-system-exec-vi/m-p/290635....
Certified LabVIEW Architect
Message 4 of 10
(5,946 Views)
I'm still getting the same error
Message 5 of 10
(5,931 Views)
The error say's you are still not having a space between cmd and /r.
Message 6 of 10
(5,905 Views)
I tried with and without and it doesn't change anything
Message 7 of 10
(5,897 Views)
I found the error it was because my path file was wrong  https://forums.ni.com/t5/LabVIEW/What-is-Error-Code-267/td-p/23804
Message 8 of 10
(5,894 Views)
/R is the same as /C
C:\> cmd /?
Starts a new instance of the Windows command interpreter
CMD [/A | /U] [/Q] [/D] [/E:ON | /E:OFF] [/F:ON | /F:OFF] [/V:ON | /V:OFF]
    [[/S] [/C | /K] string]
[ ... (Output shortened) ... ]
/V:OFF  Disable delayed environment expansion.
Note that multiple commands separated by the command separator '&&'
are accepted for string if surrounded by quotes.  Also, for compatibility
reasons, /X is the same as /E:ON, /Y is the same as /E:OFF and /R is the
same as /C.  Any other switches are ignored.
Message 9 of 10
(5,889 Views)
C:\> cmd /?
Thanks.  I was only looking at the list and never saw it.  I never looked through the pages of other comments in all those paragraphs.
Message 10 of 10
(5,872 Views)
