Running Min and Max
Hi All,
I am trying to display a "running min and max" number from 100 randomly generated numbers between 0 to 1. My VI will display the min and max at the end of the 100 iterations, but I cant figure out how to get it to display min and max while running.
Any help is appreciated, my VI is attached.
Thanks!
(2,932 Views)
Accepted by josrya
You can use the Max/Min function on the Comparison pallete, and bring the max/min indicators inside the loop.  You will need to use 2 shift registers for the previous max and min values.
(2,928 Views)
Accepted by josrya
Hi josrya,
or use Pt-By-Pt-ArrayMinMax in the loop…
(2,903 Views)
Thanks for the help!
(2,847 Views)
