Running LabView run time from Excel
I need to run a labview runtime from Excel, the problem is I do not
have LabView installed on my computer so I do not see the LabView
object library in Excel VB interface, I assumed that installing a
runtime version should install that too.
Am i missing something, or is there a way to run a labview runtime VI
using ActiveX without actually intstalling labview.
Thank You.
(3,547 Views)
Check out this post  on Accessing compiled VI`s via VBA . I think will shed some light on the subject. Also, consider making a dll instead of an exe. That may also solve the problem. Post to let us know your results. Thanks!
Chris C
(3,534 Views)
I'm hoping that this thread isn't TOO old... In any case, I am also trying to call an ActiveX server I have built with LV from Excel. If I change the reference to "Labview.application" to something like "myapp.application", the routine actually runs once and Excel stops with a "runtime error '13' type mismatch". Anybody have any ideas as to what is mismatching what?
Mike....
Certified LabVIEW Architect
LabVIEW Champion
(3,480 Views)
Hey Mike,
Two things to verify,
1. The LabVIEW run time engine is installed.
2. You've enabled ActiveX for your executable. See the picture below.
Chris C
Message Edited by Chris_C. on 02-22-2007 12:31 PM
(3,460 Views)
