07-24-2017 01:38 PM
Hi All,
I'm trying to run the same template Vi, asynchronously, more than one (3 times) in 3 separate sub-panels, all with different data being passed to them. So far I've got this:
The first sub-panel displays correctly, but the other two fail on Error 1145. Where am I going wrong? I've been following some guides for loading sub-panels, but I can't find much info on running multiple asynchronous sub-panels that use the same template Vi.
TIA
Solved! Go to Solution.
07-24-2017 01:48 PM
Try one open for each subpanel.
Ben
07-24-2017 01:52 PM
What Ben is getting at is that you are trying to run the same instance of the VI 3 times. You need to open 3 difference instances of the VI to run them in parallel.
07-24-2017 02:10 PM
Thanks, been a looong day! Seems so obvious now
Also need to remember to close the reference, running this continuously opened a lot of vi's... a lot
