Run executable program on labview
Hi Tom,
You will need to go into the LabVIEW folder, in my case is:
C:\Program Files (x86)\National Instruments\LabVIEW 2017
And the right-click on the .exe and select Run as Administrator.
You can also go into properties and enable the software to always with you as an administrator.
Randy @Rscd27@
Message 11 of 13
(1,179 Views)
wrote:
I try to run both with dir and without dir. it still did not execute
Well you don't want dir in there because all you are telling it to do is give you a directory listing of the files that match that pattern of your executable.
Message 12 of 13
(1,170 Views)
Did you create a program in LV that you're now using from command line? Then I assume you have something similar to this in your code?
To send args to LV you'll probably need '--' so your command should look like "MyApplication.exe -- 0"
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 13
(1,162 Views)
