Run Vi at the end of another
Spole,
The images you embedded do not show up because when you embedded them, you pointed to the file that was in the temporary Preview location of the NI website.  //forums.ni.com/ni/attachments/ni/170/preview/0/temp-124470-ni-170-2210-attachment
You need to actually submit your message first with the image file attached.  Once the message is submitted, then it gets assigned its permament message ID number.  Then you can right click properties on the attachment to copy its permanent forums web address.  Edit the message and embed the image based on the permanent address.  Here are those images:
Here is that VI you requested down converted to 8.0.  I fixed the properties so that it doesn't run when opened which is an annoying property to set for a VI posted to the forums.
Message Edited by Ravens Fan on 04-18-2009 12:01 AM
Message 11 of 16
(1,136 Views)
thanks for that - looking through this VI i'm still having trouble figuring out how to adapt it/learn from it to achieve what I am going for
Message 12 of 16
(1,119 Views)
bump
Message 13 of 16
(1,108 Views)
is this what I am looking for?
http://sine.ni.com/devzone/cda/epd/p/id/4447
Message Edited by spole96 on 04-19-2009 08:17 AM
Message 14 of 16
(1,088 Views)
You are looking for '404 Not Found'?
Can you explain why you want to get so complicated with property nodes, etc?  The idea I gave would seem to do exactly what you want with a minimum of fuss.
Message 15 of 16
(1,073 Views)
Accepted by spole96
here is the fixed link
it does exactly what I needed, thanks anyway
just attaching them as a reference should anyone search for this or have this same question
Message 16 of 16
(1,061 Views)
