Run Time Menu - panel close event
Hi All,
I have a quick question about the behaviour of run time menus:
I have a event structure setup to detect the Panel Close? event to handle some shutdown code before my App exits. I am wondering which of the run time menu selections triggers a Panel Close? event. I know that clicking the red "x" will trigger it, but I also want to include a "File -> Exit" option.
What is the difference between the Close and Exit items in the run time menu? Do they both trigger Panel Close? events?
Thanks!
(3,199 Views)
Accepted by topic author sirwin
File-> Exit is a labview instance exit, it says "it will abort running vi-s". It does not matter, in which VI you select this item. Very similar to red abort circle. Does not trigger Panel close event.
File-> close, Ctrl+W, Alt+F4, red cross - close current window, all trigger "Panel close?" event
(3,174 Views)
