Run-Time Engine error
I have created an automated test and had it running as an executable on a stand alone test computer. I updated my LabView software to 8.6.1. I just made some changes to the test and recompiled it. When I tried to run it on the stand alone computer it gave me an error about the LabVIEW 8.6.1 run-time engine missing. I thought when the project was built all the files that pertained to running it were also built into the folder. Has anyone run into this that could offer some advice.
Chirs
(3,458 Views)
Accepted by chirs73
Did you create an installer or simply build the exe? If you only built the exe you will need to install the run-time engine on the target machine. If you created an installer you can include the installation of the run-time engine as part of the installer.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(3,456 Views)
Thanks Mark
(3,445 Views)
