‎04-03-2009 07:12 AM
‎04-03-2009 07:22 AM
Anna Kuznetsova wrote:
Anybody knows why I can't access to VI (*.exe) on remote PC.
Why you can't able to access it?
Is there any error popping out. Please attach a screenshot if so. This will help narrow down the issue.
Mathan
‎04-03-2009
07:26 AM
- last edited on
‎07-22-2025
04:47 PM
by
Content Cleaner
Yea, there is more you need to do. Have a look at the following document:
How Do I Enable LabVIEW Web Server or Use Remote Panels With an Executable Built in LabVIEW?
‎04-03-2009 07:30 AM
‎04-03-2009 07:34 AM
‎04-03-2009 07:50 AM
Probably I need to add "www" folder with file.html to some path? And how it will be communicate with a Web Browser on the other site?
‎04-03-2009
08:03 AM
- last edited on
‎07-22-2025
04:47 PM
by
Content Cleaner
Have you used the web publishing tool on the pc which has labview installed and the vi running on it? Have a look at this document Publishing VIs on the Web. In the Web Publishing Tool, you have the option to start the web server and will be given the option to choose the web directory AND will be shown the URL to connect to the web server from a browser of any other machine.
‎04-03-2009 08:38 AM
Sure, with LabVIEW installed it works properly. But questions is "how I can to view VI interface on PC with RTE installed via Web browser in case when this VI has been uploaded on this PC?".
It is mean that we are using Web Server for this. Are you sure standard LabVIEW Run-Time Engine contains this? And as I’m understood I need to copy *.html files to somewhere…. on this PC? Thank you for support and advices 🙂
‎04-03-2009 09:14 AM
‎04-03-2009 09:34 AM
