em 06-02-2009 01:36 AM
Hi there,
Roundness can be defined by means of different methods. So far I found MRS or MZC, MIC, MCC and LSC.
Complete description in the VI as comment 🙂
So far I managed to calculate LSC because LV provide a VI for it 🙂
Can someone please help me with the other ones?
I can't finad a way to determine the radius and offset of the maximum inscribed circle and minimum circumscribed circle.
Does anyone has the formulas to calculate those circles?
Thanks a lot
Alain
Solucionado! Ir para Solução.
06-02-2009 09:22 AM - editado 06-02-2009 09:26 AM
For MIC and MCC I took the center as the (x0,y0,z0) that was returned by LSC. Then found the closest and farthest points from that point and used those as the radii for MIC and MCC.
It should be noted that I don't know if this is an official way to do the calculation. It made sense in my head though.
em 06-02-2009 09:41 AM
Thanks for the effort Tim but taking the center point from the LSC circle as zero point for MIC & MCC circles is not right 😞
And that's my problem, how to find the middle point of those circles.
I think there is a formula to determine them but I can't find them on the web 😞
I found formulas for area and gravity point but not for MIC & MCC 😞
Anyway, thanks for your work so far.
I can't open your VI, I have V8.5 instead of V8.6
Alain
em 06-02-2009 09:47 AM
em 06-02-2009 09:54 AM
Half of the job is done 🙂
I'll keep looking for the other half ![]()
Thanks for the V8.5 vi.
Alain
em 06-02-2009 10:00 AM
Since (0,0) isnt the center, how about this.
Center x-value = [(max x-value)+(min x-value)] / 2
Center y-value = [(max y-value) + (min y-value)] / 2
Then your center will be (center x, center y)
em 06-02-2009 10:03 AM
And to find out how round the circles are:
(largest diameter in y-direction) - (largest diameter in x-direction)
As this difference approaches 0, the circle is more and more circular (less eliptical)
em 06-02-2009 10:09 AM
06-02-2009 10:12 AM - editado 06-02-2009 10:13 AM
That shouldnt be a problem.
Find your maximum and minimum for both x and y values.
Find the difference between your max-y and min-y. This will be 1 diameter (in y-direction)
Find the difference between your max-x and min-x. This will be the other diameter (in x-direction)
If you subtract one of these differences from the other, you should get a (hopefully small) value.
Edit: Oh wait, you mean if the ellipse is off to an angle..... then you are correct.
Let me see if I can think of a solution to that
em 06-02-2009 10:16 AM
