Role of timing and rate in the buffered acquisition
Hi
I am trying a buffered acquisition.
In the timing VI, when i specify the rate to be around 2000, i do not get any error message and the data acqusition continues. Also i am giving a time of 1000ms in the wait until next millisecond vi in the while loop.
But if i increase the rate to be around 5000 and increase the millisecond count to 2000, then i get the following error message.
-200279   DAQmx Read (Analog 1D DBL 1Chan NSamp).vi:1<append>
<B>Property: </B>RelativeTo
<B>Corresponding Value: </B>Current Read Position
<B>Property: </B>Offset
<B>Task Name: </B>MyVoltageTask
What is the importance of timing in the while loop and specifying the rate in the timing VI????
Somil Gautam
Think Weird
(2,813 Views)
Accepted by Somil
(2,807 Views)
Thanks.
Actually, setting the timing in while loop to 1/10 th rate in the timing VI is a good practice.I had increased the timing and as a result the buffer was getting overwritten.
Somil Gautam
Think Weird
(2,796 Views)
glad :smileyhappy:
(2,792 Views)
