Ring with empty fields and negative numbers
Hello Everybody.
During some work with RS232 I found in LV example some interesting RING definition.
One of them (see attached vi) has a negative number connected with the field, and the other has a gap between field 2 and 4. In both cases the field ... is not accessible.
How it is done. I tried to create other Rings and I could not find how to do this.
I have also noticed that in those Rings you can not add or remove any fields and the Representation is disabled.
How to create such a rings.
thanks
Pawel
Message 1 of 8
(3,430 Views)
Hi pawel,
I believe those are called "sparse enums".
They can not be created in LV. They have to be created in CVI (or the like) and brought into LV.
Ben
Message 2 of 8
(3,430 Views)
Ben's right.
For more on this (and pseudo methods of implementation) see:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RNAME=ViewQuestion&HOID=5065000000080000003E2C0000&ECategory=LabVIEW.LabVIEW+General
2006 Ultimate LabVIEW G-eek.
Message 3 of 8
(3,430 Views)
Hi Ben
I see. That is even more interesting, that the controls can be created somewhere else that LV and imported and keep the functionality. Very interesting. I need to dig something more up about it.
The stratnge part is that when you create a reference to those controls, you will get a Ring reference.
regards
Pawel
Message 4 of 8
(3,430 Views)
LabVIEW 7.0 now supports sparse rings.
Message 5 of 8
(3,430 Views)
For those of us that are still finishing off applications we started in LV 6.1,
Once you create one of these can you right click, replace with enum?
Ben
Message 6 of 8
(3,430 Views)
You can, but it doesn't save the sparse data, it renumbers beginning at zero.
Message 7 of 8
(3,430 Views)
One click away from a dream come true.
Oh well, maybe LV 8.
Ben
Message 8 of 8
(3,430 Views)
