Ring array wiring with case control problem
Hello everyone. I have a problem with wiring the Ring control array with the case control. I have defined the Ring control to Long (I32) as the case, but it still says error.STRING.png
Best regards
Oesen
(2,811 Views)
You cannot wire an array to the case selector.  It requires a scalar.
How would it know which element of the array you want to use?
Use Index Array or put the case structure inside a loop and use autoindexing.
Lynn
(2,809 Views)
There is no such control as 'ring control array'. If you inserted a ring control into an array, why? You obviously cannot connect an array to a case statement. You would simply connect a single ring control.
(2,778 Views)
I'm guessing what you really want to be using here is an enum.  Then your case structure will use the defined text instead of the number.
(2,773 Views)
