Right-Click pop-up more than one Description and tip
Is it possible to edit the run-time popup menu for a right click on a control?
My front panel has a cluster within a cluster and the right-click popup menu gives you two different "Description and Tip" to select from. This is confusing for the user.
How do I edit the run-time right-click popup menu?
(2,626 Views)
You can enable or disable run time shortcut menu by going to File >> VI Properties >> Window Appearance >> Customize. There is no built in functionality to edit run time short cut menus though.
Ankita A.
(2,626 Views)
hi
search for right click, context menu etc. in this forum. there are several posted vis to create your own right-click menues and catch the selected item (some of them are really neat).
best regards
chris
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(2,626 Views)
