Reverse lookup table scaling.
Ok so I have a sensor that is polynomial THEN linear.
I have a 25pt lookup table for the calibration in MAX.
I have a data file that is the result of scaling the raw voltages into real units after going thru the lookup table.
Now I realize the lookup table is incorrect.
I need to back the lookup table out of the data to bring me back to volts.
Is there a semi easy way to do this in LV?
I have the data file and the lookup table attached.
MF100 units are correct in LB/Min.
The column "Granetelli" is the result of the lookup table.
I need to back out the calibration from the data, put the data into volts, and then figure out a new lookup table that makes those unscaled volts scale to the values that are listed in the MF100 column.
Advice?
(3,187 Views)
Vr6Fidelity,
Can you post a screen shot of your code so we can have a better idea of what you are doing.  I believe what you should try is a simple Analog Input Voltage aquire to get your raw voltage data, but I would like to make sure.
Mark
NI App Software R&D
(3,162 Views)
What I was trying to do would have been really complicated. Instead I just repeated the test with that channel set to "no scaling" and I have what I need now. Thank you.
(3,160 Views)
