Restarting a given COM port
I keep loosing communication with an instrument randomly. Sometimes data acquisition works trouble free for days , sometimes for a couple of hours. After I've lost the communication i must restart both the PC and the instrument.
Can i force a specific COM port to restart run-time in labview? I am using an RS232 DB9 connector with shielded cable of length 1 meter.
Have you got any ideas how to solve this technical issue?
Kind regards,
Balázs
(3,032 Views)
What do you mean by restarting the COM port? You can close it by calling VISA Close and then open/configure it again. Do you keep the port open all the time while the program is running? Any error when the communication is lost?
Lucian
CLA
(3,006 Views)
Yes, opening and configuring it again does not help. Please visit this topic to see the errors.
https://forums.ni.com/t5/LabVIEW/Communication-stucks-with-Ketihley-2700-data-logger/td-p/4021341
(2,964 Views)
At any point does your program go into a idle state for a period of time? Are you using a serial to USB converter?
It would help us if you uploaded your VI too.
(2,954 Views)
Accepted by topic author LTBALAZS
Yikes! Assuming that the SW is written correctly, this might indicate a ground loop or ESD problem. Or maybe a power problem? Have you try using a laptop?
Another thing to try is to throw away the Keithley supplied instrument drivers and code up your own.
BTW. It is very hard to troubleshoot intermittent problems like yours.
(2,948 Views)
Hi, it was ground loop problem.
(2,875 Views)
