Resizing the front panel in Labview 6
I would like to resize my front panel dependent upon the screen resolution. Everything is working fine except for a tab control that is not visible when the initial front panel is displayed. Depending on a selection from a treeview, the tab control will be displayed. A listbox and graph is on one panel and a collection of strings are located on the other panel. The tab control does not attempt to resize to the screen setting. I can set the size of the tab panels, but the information on the panels does not resize. Any help?
(2,787 Views)
Is this the same posting as this one from earlier? If you've contacted NI and they said it's a problem, I supposed they'll submit it to R&D.
J.R. Allen
(2,787 Views)
It is the same posting. When I orginally posted the question it ended up under Labview Real-Time. It should have been under Labview General. I am not using Real-Time.
(2,787 Views)
