Resetting buttons
I was just wandering. I have a button whose mechanical function is set to "switch until released". Is there a way I could hit the button and have it on "switch when pressed" then when a particular function or event has occurred have it reset to the default "false" state?
Cheers
K
Message 1 of 9
(4,988 Views)
Yes, this is one of the few good places to use a local variable.  The local variable is a better choice here than using a property node.
Message 2 of 9
(4,987 Views)
Here is a good link for why the local variable is a better solution here, if you are interested.
Message 3 of 9
(4,981 Views)
hey there,
not sure what i'm supposed to be looking at.
could you point out a few things? isn't using a local gonna be the same at the current true/false of the button?
Message 4 of 9
(4,969 Views)
Accepted by Kamilan
Just write a false in the local variable, after the button is pressed
Message 5 of 9
(4,953 Views)
Precisely, sorry I wasn't more descriptive.
Message 6 of 9
(4,916 Views)
Hi there,
Thats for the picture. That did the trick 🙂
Cheers
Message 7 of 9
(4,885 Views)
Picture attached 🙂
Chris Bolin
LabVIEW Partner Program, CLA
Message 8 of 9
(4,855 Views)
Thank you for the picture CXB!
Message 9 of 9
(4,722 Views)
