07-24-2014 02:35 PM
Does a call to "DAQmx Reset Device.vi" reset all modes of multi-function DAQ hardware or only those associated with the task that's wired to the input? In other words, if the hardware includes Analog Input, Analog Output and Digital I/O, for example, does the reset apply to all modes or just those associated with the input task? In this case it's a USB-6366, but the question applies to any multi-function DAQ.
Don
07-24-2014 02:49 PM
07-24-2014 02:51 PM
Currently I don't. I'm including the capability as part of a somewhat generic app.
Thanks for the reply.
Don
07-24-2014 02:53 PM
Is the same true of the Self-Test vi?
07-24-2014 03:08 PM
07-24-2014 03:11 PM
OK, thanks. I'm writing most of the code with a simulated front end so I can't check everything out on real hardware right away.
07-28-2014 02:11 PM
Not sure if this is applicable, but you can simulate DAQmx devices in MAX. Then in LabVIEW they appear as normal devices and can be used as normal devices. Many times I write code to simulated devices to test to see if some code can run. Obviously there is no output but you would be surprised what kind of errors you can find before having hardware using this technique.
http://www.ni.com/white-paper/3698/en/
http://digital.ni.com/public.nsf/allkb/75CF478A58545DFC86256FCC006E25A2
Get going with G! - LabVIEW Wiki.
17 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
