Reset a feedback node within a loop
Hi everyone,
I am new user of LabVIEW and sometimes even the most simple task seems to be very difficult for me.
What I am trying to do is this:
1. Reading a signal (I am using the random generator in the example below).
2. Display the signal on the screen (the Waveform Charts)
3. When I press a button, a predefined number of signals should be saved to file.
I have managed to both display the signal and save it to file, but I am unable to find a way to stop the file saving when enough signals have been saved.  I am now trying to count the signals saved using a Feedback Node.  This works fine the first time the button is pressed, but the next time the button is pressed, the Feedback Node continues from the last time, ie. it is only reset when the outer While-loop is run the first time.
So my questions are:
1. Is it possible to reset the Feedback Node when the Boolean variable as shown in the example changes from True to False?
2. Is there a better way to save the data (and being able to display it to screen (and later using the data in the VI)).
Martin T.
(15,933 Views)
Accepted by topic author Martin_T
Yes you can using a simple 'Select' function:
Ton
Message Edited by TCPlomp on 29-10-2009 10:09 AM
My LabVIEW Ideas
(15,925 Views)
Instead of feedbak loop you can use shift register and can initialize the shift register within the case.
Visuman
(15,921 Views)
Excellent!  This solution works exactly the way I wanted it to!
Thanks a lot!
Best regards, Martin
(15,895 Views)
@visuman 10-29-2009 04:12 AM
I tried earlier to see if I could use Shift Registers, but I didn't manage to add one to a Case Structure.  Is it possible to add a Shift Register to a Case Structure, and if so, how do I do it?
Best Regards, Martin
(15,892 Views)
The shift register would be added to the loop and its wire would be passed through all of the cases in the cases structure. You would only need to wire through the case structure if the value of that wire was modified in any case. If you were only reading the value inside the case structure you would not have to wire it through the case structure. In addition, if you wire it through the case it must be connected in every case.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
(15,873 Views)
