Reset LabVIEW Example
I accidentally made modifications on an example VI from the built-in examples in LabVIEW instead of making a copy. I would like to be able to see the original example again. How do I reset the example?
(3,867 Views)
You can delete it and run a "repair" on your LV installation. Or if it's just one or two, post here and someone can provide a "clean" example VI for you to download.
And kudo this idea:
https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Easily-revert-shipping-examples-in-NI-Example-Finder-...
(3,835 Views)
Thanks for the info! If someone is able to post Edge Detection.vi here (under Examples > Toolkits and Modules > Vision > Caliper), that would be greatly appreciated! Otherwise I can try to go through the resetting process you linked.
(3,802 Views)
I don't have the Vision toolkit installed right now so I don't have that example, sorry 😞
BTW, it might help to post what LV version you're looking for.
(3,798 Views)
Sorry, I forgot that was from an add-on but I appreciate you trying. I am using LabVIEW 2020 Student Edition.
(3,796 Views)
