Require to add elements of a byte array
I have a byte array - meaning all the numbers are between 0 - 255.
I need to add all of them in a binary/ hex addition format. Meaning the summation will still be an 8 bit number and stay between 0 - 255. The extra bit (9th bit) that is created with summation of two numbers will be ignored.
Example: 254 + 254 = 508 in decimal summation
           254 + 254 = 253 in binary addition
Is there a way to solve this with a single vi, and not manually implementing the algorithm.
Message 1 of 11
(6,071 Views)
How about this?
=== Engineer Ambiguously ===
Message 2 of 11
(6,060 Views)
True this works, but I am seeking an array addition of all elements, where I have like 20 elements.
IT is a byte array.
Message 3 of 11
(6,058 Views)
Something like this?
Message 4 of 11
(6,044 Views)
Hi RTSLVU
Not really, I want to add all the elements in a single array. For example the first array you have with eleemnts: 255 254 253 252 253 ; I want to add all those five and get the result to do manipulations with that later on in my code.
Message 5 of 11
(6,042 Views)
Accepted by looser_engineer
Ohh... Right off the top of my head I would do this...
Message 6 of 11
(6,039 Views)
or this...
aputman
Message 7 of 11
(6,022 Views)
Unless you initialize that shift register, surprises will happen 😮 Not good!
(yes, I would just go withe the "add array elements" above)
Message 8 of 11
(6,008 Views)
You know I was looking for Add Array elements and for the life of me I could not find it in the pallette
Message 9 of 11
(6,002 Views)
Yes, it is surprising that it is NOT in the array palette :D.
Message 10 of 11
(5,986 Views)
